Address Handler Editor
Use the Address Handler editor to configure address handlers. To access the Address Handler editor, double-click an address handler entity.
Use the Details tab to select the implementation class for the address handler and to specify information about the address handler.
| Field | Use |
Implementation Class |
Specify the Java type that implements the specification. Create a new class or select an existing one. |
Implementation Prefix |
Displays the value of the component name. |
Documentation |
Specify any other information about the address handler. |
