Action Editor Realization Tab
Use the Realization tab to associate the Network Integrity action with a conceptual model technical action.
| Field | Use |
Realizes |
Opens the selected technical action in the Action editor. |
Select |
Associates the Network Integrity action with a conceptual model technical action. To select from the available conceptual model technical actions, there must be a dependency defined between your Network Integrity cartridge project and the Model project in which your conceptual model is saved. See "Managing Cartridge Dependencies" for more information. |
