Action Editor Conditions Tab
Use the Conditions tab to view and manage the conditions on an action.
Conditions Area
| Field | Use |
Conditions table |
Lists the condition on the action. |
Remove |
Removes the selected condition from the action. |
Add |
Creates a condition. |
Condition Details Area
| Field | Use |
Condition Details table |
Provides further details on the selection condition from the Conditions table. |
Implementation Class |
Specifies or creates a new Java implementation class for the condition. Click Implementation Class to create a new class for the processor implementation. Click Select to select an existing class for the processor implementation. |
Input Parameters table |
Specifies the input parameters that determine the result of the condition. |
Open |
Opens the Processor editor for the processor to which the selected input parameter is output. |
Remove |
Removes the selected input parameter. |
Select |
Adds an existing parameter, output from a predecessor processor in the sequence of processors in the action, as input to determine the result of the condition. |
