Action Editor Result Source Tab
Use the Result Source tab to view and manage the result sources on discrepancy detection and discrepancy resolution actions.
| Field | Use |
Result Source table |
Adds a result source to the action. Result sources come from the result category on discovery, import, or assimilation actions. If the result category of the source action that this action acts against is set to All, this action acts against all the results that are generated by the source action. |
Open |
Edits the selected result categories for the selected result source. |
Remove |
Removes the selected result source from the action. |
Add |
Add a result sources (and result categories) on the action. |
