Adding Address Handlers to Network Integrity Actions
This procedure assumes you have a cartridge project with address handlers. Oracle Communications provides basic address handlers in the Address Handler cartridge provided with Network Integrity.
To add an address handler to a discovery action:
  1. On the Action editor Details tab, beside the Address Handler field, click Select.
    The Select Address Handler dialog box appears. The dialog box lists address handlers from dependent cartridge projects only. See "Managing Project Dependencies" for more information.
  2. From the Matching Items list, select an address handler.
    You can filter the Matching Items list by typing in the Select an item to open field.
  3. Click OK.
    The name of the address handler appears in the Address Handler field.
  4. Save the action.
