About Result Categories for Network Integrity
A result category is the identifier for a result group. It is used to identify and save scan results to the corresponding result model.
The name of the result category must match the name of the result group in the Java implementation into which the scan results are saved. The result category name appears in the Network Integrity UI scan results.
Assimilation, discovery, and import actions must be configured with a valid result category.
