Configuring Network Integrity Processors
To configure a processor:
  1. Open the Processor editor Details tab.
  2. (Optional) In the Description field, enter a description for the processor.
  3. In the Implementation Class field, do one of the following:
    • To create a new Java implementation class, click the Implementation Class link.
      The New Java Class dialog box appears. Click the Help icon in the dialog box for more information about creating the Java class.
    • To choose an existing implementation class, click Select.
      The Select Java Implementation dialog box appears.
      Select an implementation class from the Matching Items list. You can filter the Matching Items list by typing in the Choose type that implements interface field.
  4. (Optional) In the Documentation field, enter additional information about the processor.
  5. Add context parameters.
    See "About Context Parameters for Network Integrity Processors" for more information.
  6. Add property groups and properties.
    See "About Properties and Property Groups" for more information.
  7. Save the processor.
