Creating Network Integrity Processors
You can create processors as part of configuring an action or you can create them independently.
See "Adding New Processors to Network Integrity Actions" for more information about creating processors as part of configuring an action.
To create processors independently:
  1. From the Studio menu, select New, then select Integrity, then select Processor, and then select one of the processor types.
    The Processor Wizard for the type of processor you selected appears.
  2. From the Project list, select the cartridge project in which to include the processor.
  3. In the Name field, enter a name for the processor.
    The Implementation Prefix field takes the component name by default.
  4. (Optional) In the Folder field, select a location for the processor.
    If you leave the Folder field blank, the specification is created in the default workspace.
  5. Click Finish.
    Design Studio creates the new processor and displays the Processor editor.
  6. Configure the processor.
