Adding Existing Processors to Network Integrity Actions
This procedure assumes that you have already created and configured a processor for your action.
To add an existing processor to an action:
  1. On the Action editor Processors tab, click Select.
    The Select an Action or Processor to Add dialog box appears. The dialog box lists processors from the current cartridge project and actions from dependent cartridge projects. See "Managing Project Dependencies" for more information.
  2. From the Matching Items list, select a processor or action.
    You can filter the Matching Items list by typing in the Select an item to open field. Only valid entities for the action type appear in the Matching Items list.
  3. Click OK.
    Design Studio adds the processor to the action.
  4. Save the action.
