Action Editor Scan Parameter Groups Tab
Use the Scan Parameter Groups tab to view and manage the scan parameter groups for assimilation, discovery, and import actions.
Field Use
Scan Parameter Groups Section table
Lists the scan parameter groups on the action, and to which cartridge project they belong.
Move Up
Move Down
Reorder the selected scan parameter group for the action.
Select
Add an existing scan parameter group to the action, or a scan parameter group from a dependent cartridge project.
Open
Open the Scan Parameter Group editor for the selected scan parameter group.
Remove
Remove the selected scan parameter group from the action.
Add
Create a new scan parameter group and adds it to the action.
