About the Network Integrity File Parser Processor
The file parser processor is a fully-implemented, code-generated processor that parses XML- and ASCII-delimited files into Java. The file parser processor outputs an iterable that the other processors can use to access the records and data in the file.
The file parser processor can be used in discovery, import, and assimilation actions.
For more information about file parsing, see Network Integrity File Transfer and Parsing Guide.
