Configuring File Transfer Properties for Network Integrity File Transfer Processors
The file transfer context parameters are set in predecessor processors in the sequence of processors in the action so that some or all of the properties can be defined in the action. You can configure the action to specify all the file transfer properties programmatically, rather than requiring the user to enter values.
For example, when a processor at the beginning of an action calls an external system or device to generate a file containing device data, the processor triggers the generation of a file, and then programmatically sets the file transfer properties with information such as file name pattern and the directory where the file can be found.
To select the file transfer context parameters:
  1. Click the Processor editor File Transfer tab for the file parser processor.
  2. In the Input Parameters area, click Select.
    The Select Output Parameter dialog box appears listing, oracle.communications.sce.integrity.sdk.fileTransfer context parameters output by predecessor processors in the sequence of processors in the action. If there are no available context parameters, an error message appears.
  3. Select a parameter.
  4. Click OK.
