About Network Integrity Specifications
A specification is a representation of an Oracle Communications Information Model entity that is augmented with characteristics using Oracle Communications Design Studio. Each specification relates to a single Information Model entity. You can create multiple specifications that all relate to or extend the same entity.
All actions must specify which specification types they support. By default, actions support all specifications created in the same cartridge project as the action.
Specifications can be shared between cartridges. When multiple cartridges are deployed together, their shared specifications are compatible. To add specifications to actions from another cartridge project, the specifications must be added to a model collection and the model collection added to the action.
