Creating Network Integrity Specifications
To create a specification in an Integrity cartridge project:
  1. From the Studio menu, select New, then select Integrity, and then select a specification from one of the following submenus:
    • The Administration menu
    • The Infrastructure menu
    • The Resources menu
    • The Services menu
    The Specification Wizard for the type of specification you selected appears.
  2. From the Project list, select the cartridge project in which to include the specification.
  3. In the Name field, enter a name for the specification.
  4. (Optional) In the Folder field, specify a location for the specification.
    By default, Design Studio saves the entity to your default workspace. You can browse to a different location using the Browse button.
  5. Click Finish.
    Design Studio creates the specification and automatically adds it to all actions in the same cartridge project as the specification.
  6. Configure the processor. See "Configuring Network Integrity Specifications" for more information.
