Adding Existing Characteristics to Network Integrity Specifications
To add existing characteristics to a specification:
  1. On the Specification editor Characteristics tab for a Network Integrity specification, right-click the data tree area and click Select Characteristic.
    The Select Characteristic dialog box appears. The dialog box lists characteristics from the current cartridge project and from dependent cartridge projects. See "Managing Project Dependencies" for more information.
  2. Select one or more characteristics.
    You can filter the list by element name by typing in the Element field and clicking the Filter icon, or by entity name by typing in the Entity Name field and clicking the Filter icon.
  3. Click OK.
    Design Studio adds the characteristics to the Specification editor Characteristics tab.
