Defining Network Integrity Specification Layouts
You define layouts for specifications to specify how and where characteristics appear as fields in the Network Integrity UI scan results.
To define specification layouts:
  1. On the Specification editor Layouts tab, select a characteristic.
    Design Studio for Network Integrity does not support suppressing characteristics from the run-time UI. All characteristics appear in the run-time UI.
  2. Organize the order of the characteristics:
    1. From the Selected list, select a characteristic.
    2. Click the Up Arrow or Down Arrow icons.
  3. (Optional) To add rows, right-click a characteristic and select Insert New Row.
    Characteristics appear in the order indicated from left to right in the Network Integrity UI. By inserting a row, the proceeding characteristics restart on the left of the UI on a new row.
  4. Save the specification.
Clicking the Reset button resets the order of the characteristics in the Panels / Elements area and remove any added rows.
