About the Characteristics Tab Context Menu
The Characteristics tab context menu contains actions specific to data elements tagged as characteristics. To access these actions, right-click in the left column of the tab. The context menu options that are available depend on the selection in the editor. For example, the list of context menu options that appear when you right-click in the white space is different than the list that appears when you right-click a characteristic.
| Command | Use |
Delete |
Select to delete the characteristic from the specification. |
Refactoring |
Select to access a menu of options for improving names and locations of the characteristics. See “Managing Data Element Names and Locations" for more information. |
Refresh |
Refreshes the view. |
Add Characteristic |
Select to create a new data element (that is automatically tagged as a characteristic) to add to the specification. See "Creating Characteristics" for more information. |
Select Characteristic |
Select to add an existing data element (tagged as a characteristic) to the specification. See “Tags Tab" for more information about tagging data elements as characteristics. |
