Specification Editor Characteristics Tab
Use the Characteristics tab to create, select, edit, and remove characteristics. See "Creating Characteristics" and "Adding Characteristics to Specifications" for more information about adding characteristics to Specification editors.
The default data elements that appear in the Characteristics tab data tree are inherited from the extended entity, defined in the ora_uim_model project. These default data elements are read-only.
When working with the Specification editor Characteristics tab, see the following topics:
