Adding Characteristics to Specifications
You can add existing characteristics to specifications. For example, you can add a characteristic that was originally created for use in one specification to a different specification.
You can also create new characteristics in Specification editors. See "Creating Characteristics from the Specification Editor" for more information.
To add existing characteristics to a specification:
Create a new specification or open an existing specification in the Specification editor.
See "Creating New Specifications" for more information.
Click the Characteristics tab.
In the data tree area, right-click and select Select Characteristic.
The Select Characteristic dialog box appears.
See "Select Characteristic Dialog Box" for more information.
Select a characteristic and click OK.
The characteristic appears in the Characteristics tab data tree.
From the File menu, select Save.
Related Topics
