Deploying Inventory Cartridge Projects
You deploy Design Studio Inventory cartridge projects from the Environment perspective. The method that you use to deploy cartridge projects is the same for all Design Studio features. See “Deploying Cartridge Projects" for more information.
If you are deploying into a UIM environment that is a clustered server or where UIM is running on a managed server that is separate from the administration server, you must define the wladmin.host.name and wladmin.host.port cartridge management variables. See "Design Studio for Inventory Cartridge Management Variables Tab" for more information.
