Capacity Provided Specification Editor Properties Tab
Use the Properties tab to create a new capacity type or select an existing one.
| Field | Use |
Capacity Type |
Determines the type of capacity offered, defined by a capacity type. Do one of the following:
Clear |
Click to remove a new capacity type. |
Total Amount |
Enter the amount of the capacity type that an entity can provide. |
Unit of Measure |
Select the units by which the total amount is measured, defined by a Unit of Measure specification. Do one of the following:
Consumable Percentage |
Select the percentage of the total amount that can be consumed. A consumable percentage over 100% indicates that the capacity can be oversubscribed. |
