Changing Specification Relationship Properties
After you have defined a relationship between specifications, you can change the relationship's properties.
To change relationship properties:
Open the Specification editor of a specification whose relationship properties you want to change.
Click the Related Specifications tab.
Scroll to the section for the entity type of the specification relationship you are modifying.
Select a specification from the list and click Modify.
The Relationship Properties dialog box appears.
Enter or change relationship properties.
See "Specification Editor Related Specifications Tab" for more information about the properties that you can change.
Click OK.
Design Studio sets the properties and closes the dialog box.
Related Topics
