Configuring a Card
A card is an equipment category to which you assign an Equipment specification. When you configure a card specification, you assign a template that determines the card's orientation. You can choose a vertical or a horizontal orientation.
You must configure a Card specification in the Visualization tab before it can be added to shelves.
To configure a card specification:
Create a new Equipment specification and assign it to the card category, or navigate to the editor of an existing card specification.
See "Creating New Specifications" for more information.
In the Equipment Specification editor, click the Visualization tab.
The Visualization tab displays the Default Cards subtab in the Palettes tab.
From the Default Cards area, drag a card template to the canvas.
Select a card in the canvas, then enter information about it in the information area below the Palettes area.
You may need to make the Visualization tab larger to see the information area. See "Defining Visualization Tab Item Elements" for more information.
From the File menu, select Save.
