Defining Visualization Tab Item Elements
You can define information about shelves, empty slots, cards, and card carriers in the Equipment Specification editor Visualization tab. The information is in the form of name-value element pairs.
To enter elements for items in the Visualization tab:
  1. Open an Equipment specification in the Equipment Specification editor.
  2. Click the Visualization tab.
  3. In the canvas, click a card, card carrier, or empty slot to select it.
    To select a shelf, click its perimeter. The selected item is highlighted in the canvas and information about it appears in the information area.
  4. Enter or select values for the relevant elements.
    The elements you can specify depend on the item selected in the canvas. See the following topics for information about the slotNumber and nativeEMSName elements:
  5. From the File menu, select Save.
