Configuring an Entity Identification Specification
After you create an Entity Identification specification, you must configure it.
To configure an entity identification specification:
Open an existing Entity Identification or create a new Entity Identification specification.
See "Creating New Specifications" for more information.
In the Entity Identification Specification editor, click the Specification Properties tab.
Enter the start date, end date, and description.
Click the Properties tab.
(Optional) In the Prefix field, enter an alphanumeric sequence of characters to append to the beginning of the numeric sequence of the ID value.
(Optional) In the Suffix field, enter an alphanumeric sequence of characters to append to the end of the numeric sequence of the ID value.
Do one any of the following:
Click Sequence Specification to create a new Sequence specification.
Click Select to select an existing Sequence specification.
Click Clear to remove a previously associated Sequence specification.
From the File menu, select Save.
Related Topics
