Connectivity Signal Termination Point Specification Editor Properties Tab
Use the Properties tab to review details about a Connectivity Signal Termination Point specification, including its type and rate code. This information is read-only.
| Field | Use |
Display Name |
Enter the name that appears in Design Studio editors and in UIM. Design Studio supports multiple languages for this field. The field adjacent to Display Name displays your list of languages. You can define a display name for any language you select from the list. If your preferences are set to use one language only, the system displays only the [default] option. See “Defining Language Preferences" for more information. |
Name |
Displays the name of the connectivity signal specification. |
Termination Point Signal Type |
Displays the type of the signal. Values are:
Transmission Signal Type |
Displays the physical nature of the transmission signal, such as Optical or Electrical. |
Rate Code |
Displays the rate code that identifies the technology and bit rate for the signal. |
Valid for Facility |
Indicates whether the signal can be mapped to a connectivity through the associated rate code. |
