Connectivity Signal Termination Point Specification Editor Child Signal Relationships Tab
Use the Child Signal Relationships tab to review details about the hierarchical relationships of a Connectivity Signal Termination Point specification. See UIM Concepts and UIM Information Model Reference for more information about these relationships.
This tab is relevant only for channelized (non-packet) Connectivity Signal Termination Point specifications.
| Field | Use |
Supports Child Signals |
Lists child signals that can be enabled by the signal defined by this specification. (The supported signals are sometimes called riders.) For example, a VT-6 SPE channel signal can support (enable) a T-Carrier DS2 transmission facility. |
Aligns to Child Signals |
Lists child signals that are not located in a fixed position within an SDH or SONET frame signal. For example, in the SONET technology, a VT-1.5 processing signal aligns to a VT-1.5 SPE signal termination point. |
Maps to Child Signals |
Lists child signals that are mapped to this signal with the same rate. For example, in the SDH technology, a VC-2 processing signal maps to a C-2 signal termination point. |
Multiplexes to Child Signals |
Lists child signals into which this signal can be multiplexed. For example, in the SDH technology, a TUG-2 processing signal multiplexes to four TU-11 processing signals. |
