Copying Specifications
You can copy specifications from one project to another. For example, you can extend a cartridge pack by copying a specification into your own project and make any necessary modifications.
To copy specifications:
From the Studio menu, select Show Design Perspective.
Click the Cartridge tab.
In the Solution view, locate the target specification.
The project must exist in the same workspace. See “Importing Projects" for information.
Right-click the target specification and select Copy.
Navigate to the source project.
Right-click the source project and select Paste.
The Set Name of Copy dialog box appears.
In the Name field, enter a unique name for the specification.
Specification names must be unique in the workspace.
Click OK.
The specification is added to the source project.
