Reviewing Specification Extensions
To review a specification extension:
In a Specification editor, click the Extends tab.
Review the value in the Extends field.
Design Studio automatically populates the value in the Extends field when you create new specifications. You can remove the value, but you cannot make a different selection.
(Optional) To open the business entity that is extended by the specification, click Extends.
(Optional) To remove the association, click Clear.
Related Topics
