Device Interface Specification Editor Properties Tab
Use the Device Interface Specification editor Properties tab to associate a rate code to the device interface.
You must import the ora_uim_basetechnologies base cartridge and add the ora_uim_basetechnologies base cartridge as a dependency to your cartridge project to have access to the delivered set of rate codes.
| Field | Use |
Display Name |
Enter the name that appears in Design Studio editors and in UIM. Design Studio supports multiple languages for this field. The field adjacent to Display Name displays your list of languages. You can define a display name for any language you select from the list. If your preferences are set up to work in one language only, the system displays only the [default] option. See “Defining Language Preferences" for more information. |
Rate Code |
Displays the rate code of the device interface. Click Select to access a set of available rate codes. If this field is populated, you can click the Rate Code link to review the attributes of the rate code. |
Clear |
Click to remove the selection in the Rate Code field. |
Select |
Click to select a rate code to associate with the device interface specification. Rate codes are available only if you have imported the ora_uim_basetechnologies base cartridge and added the ora_uim_basetechnologies base cartridge as a dependency to the project in which the device interface specification is saved. |
Related Topics
