Device Interface Specification Editor Related Specifications Tab
Use the Related Specifications tab to define and review specification relationships. Only relationships with the entity types listed in this tab are meaningful by default in UIM. If you add specifications to the Others section, you must define custom rulesets that trigger actions or behavior based on those relationships.
| Section | Use |
Device Interfaces |
Lists the specifications of device interfaces that can be sub-device interfaces of device interfaces based on this specification. |
Roles |
Lists roles to which entities based on this Device Interface specification can be assigned. |
Logical Devices |
Lists specifications of logical devices that can provide device interfaces based on this specification. |
Network Nodes |
Lists specifications of network nodes that can represent device interfaces based on this specification. |
Others |
Lists specifications of entities that have a customized relationship with entities based on this specification. |
