Equipment Specification Editor Properties Tab
Use the Properties tab to define an Equipment category and enter information about the equipment.
Field | Use |
Equipment Category |
Select a category for the equipment. You can select CARD, SHELF, or RACK. |
Required Holders |
Select the number of holders required for instances of this specification. This field is applicable to the CARD category only. |
Vendor |
Lets you enter the name of the vendor of the equipment. |
Model Number |
Enter the model number of the equipment. |
Part Number |
Enter the part number of the equipment. |
