Equipment Specification Editor Visualization Tab
Use the Visualization tab to configure an Equipment specification that has been assigned to a Card, Shelf, or Rack category.
| Field | Use |
Palettes |
Use the templates on this tab to define the basic structure of the equipment. The Palettes tab contains subtabs that depend on whether the Equipment specification is defined as a card, a rack, or a shelf. |
Hierarchy |
View Equipment configuration in a tree view. The tree view reflects the configuration in the canvas, so it updates as you add new items to the visualization. When you select an item in the canvas, the corresponding item in the tree view is highlighted; when you select an item in the tree view, the corresponding item in the canvas is highlighted. |
Canvas |
Configure the equipment by dragging items from the Palettes tab. |
Default Cards |
Displays the default selection of card templates. This subtab appears if the Equipment specification is defined as a card. |
Default Shelves |
Displays the default selection of shelf templates. This subtab appears if the Equipment specification is defined as a shelf. |
Shelves |
Displays a list of the shelves (Equipment specifications in the Shelf category) that have been defined in the workspace. This subtab appears if the Equipment specification is defined as a shelf. |
Cards |
Displays a list of the cards (Equipment specifications in the Card category) that have been defined in the workspace. This subtab appears if the Equipment specification is defined as a shelf. |
Empty Slots |
Displays a list of the slots (Equipment Holder specifications) that have been defined in the workspace. This subtab appears if the Equipment specification is defined as a shelf. |
Shelves |
Displays a list of the shelves (Equipment specifications in the Shelf category) that have been defined in the workspace. This subtab appears if the Equipment specification is defined as a rack. |
