Equipment Specification Editor Related Specifications Tab
Use the Related Specifications tab to define and review specification relationships. Only relationships with the entity types listed in this tab are meaningful by default in UIM. If you add specifications to the Others section, you must define custom rulesets that trigger actions or behavior based on those relationships.
Section Use
Inventory Groups
Lists the specifications of inventory groups to which equipment based on this specification can belong.
Roles
Lists roles to which entities based on this Equipment specification can be assigned.
Physical Connectors
Lists specifications of physical connectors that can be provided by equipment based on this specification.
Network Nodes
Lists specifications of network nodes that can represent equipment based on this specification.
Physical Ports
Lists specifications of physical ports that can be provided by equipment based on this specification.
Equipment Holders
Lists specifications of equipment holders that can be provided by equipment based on this specification.
Others
Lists specifications of entities that have a customized relationship with entities based on this specification.
