Order Data Tab
Use the Order Data tab to view the contents of the Engineering Work Order specification. All information in this tab is read-only.
| Field | Use |
Task List |
Displays a list of the activities and associated tasks in the Engineering Work Order specification. |
Related Specifications |
Displays a list of related specifications for the task selected in the Task List table. |
Related Tasks |
Displays a list of the Task specifications that include the specification selected in the Related Specifications table. |
