Engineering Work Order Properties Tab
Use the Engineering Work Order Properties tab to select and view a Process specification for this Engineering Work Order specification.
| Field | Use |
Process |
Displays the Process specification (if any) associated to this Engineering Work Order specification. Click the Process link to:
See "Associating a Process Specification to an Engineering Work Order Specification". |
Related Topics
