Flow Interface Specification Editor Flow Interface Configuration Tab
Use the Flow Interface Configurations tab to enter information about the Flow Interface Configuration specification. Only one Flow Interface Configuration specification can be associated to a Flow Interface specification.
| Field | Use |
Flow Interface Configuration |
Displays the name of the Flow Interface Configuration specification. |
Cartridge |
Displays the name of the cartridge project into which the Flow Interface Configuration specification is built. |
Select |
Click to select an existing Flow Interface Configuration specification. |
Open |
Click to open the selected configuration in the Flow Interface Configuration Specification editor. |
Remove |
Click to remove the Flow Interface Configuration specification. |
Add |
Click to add a new Flow Interface Configuration specification. |
Related Topics
