Flow Interface Specification Editor Properties Tab
Use the Properties tab to enter information about the Flow Interface specification.
| Field | Use |
Display Name |
Enter the specification name as it should be displayed. |
Technology |
Select the technology. Only packet technologies are valid. Available by default are:
These technologies are supplied in the ora_uim_basetechnologies cartridge. You can edit the specifications but you cannot create new ones. |
Termination Type |
Select the termination type:
The Termination Type and Termination Packet Rider values interact. If you select a Termination Type value, Termination Packet Rider check box is deselected. If you select the Termination Packet Rider check box, the Termination Type list becomes unavailable. |
