Logical Device Configuration Specification Editor Logical Device Specs Tab
Use the Logical Device Specs tab to select, add, and remove the Logical Device specifications that use the Logical Device Configuration specifications. This tab identifies the Logical Device specifications that use the selected Logical Device Configuration specification. You must use this tab to relate a Logical Device specification to its Logical Device Configuration specification only when the Logical Device specification and Logical Device Configuration specification need to be in separate cartridges and the Logical Device specification can exist without the Logical Device Configuration specification. If both the Logical Device specification and Logical Device Configuration specification are in the same cartridge, make the association on the Logical Device specification.
| Field | Use |
Logical Device Configuration |
Displays the name of the Logical Device specification. |
Cartridge |
Displays the name of the cartridge project into which the Logical Device specification is built. |
Select |
Click to select an existing Logical Device specification. |
Open |
Click to open the selected specification in the Logical Device Specification editor. |
Remove |
Click to remove a Logical Device specification. |
Add |
Click to add a new Logical Device specification. |
