Logical Device Specification Editor Logical Device Configurations Tab
Use the Logical Device Configurations tab to enter information about the Logical Device Configuration specification.
| Field | Use |
Logical Device Configuration |
Displays the name of the Logical Device Configuration specification. |
Cartridge |
Displays the name of the cartridge project into which the Logical Device Configuration specification is built. |
Select |
Click to select an existing Logical Device Configuration specification. |
Open |
Click to open the selected configuration in the Logical Device Configuration Specification editor. |
Remove |
Click to remove the Logical Device Configuration specification. |
Add |
Click to add a new Logical Device Configuration specification. |
Related Topics
