Logical Device Specification Editor Related Specifications Tab
Use the Related Specifications tab to define and review specification relationships. Only relationships with the entity types listed in this tab are meaningful by default in UIM. If you add specifications to the Others section, you must define custom rulesets that trigger actions or behavior based on those relationships.
| Section | Use |
Inventory Groups |
Lists specifications of inventory groups to which logical devices based on this specification can belong. |
Device Interfaces |
Lists specifications of device interfaces that can be provided by logical devices based on this specification. |
Roles |
Lists roles to which logical devices based on this specification can be assigned. |
Logical Device Accounts |
Lists specifications of logical device accounts that can be associated with logical devices based on this specification. |
Network Nodes |
Lists specifications of network nodes that can represent logical devices based on this specification. |
Logical Devices |
Lists specifications of logical devices that can be children of logical devices based on this specification. |
Others |
Lists specifications of entities that have a customized relationship with entities based on this specification. |
