Logical Device Account Configuration Specification Editor Logical Device Account Specs Tab
Use the Logical Device Account Specs tab to select, add, and remove the Logical Device Account specifications that use the Logical Device Account Configuration specifications. This tab identifies the Logical Device Account specifications that use the selected Logical Device Account Configuration specification. You must use this tab to relate a Logical Device Account specification to its Logical Device Account Configuration specification only when the Logical Device Account specification and Logical Device Account Configuration specification need to be in separate cartridges and the Logical Device Account specification can exist without the Logical Device Account Configuration specification. If both the Logical Device Account specification and Logical Device Account Configuration specification are in the same cartridge, make the association on the Logical Device Account specification.
| Field | Use |
Logical Device Account Configuration |
Displays the name of the Logical Device Account specification. |
Cartridge |
Displays the name of the cartridge project into which the Logical Device Account specification is built. |
Select |
Click to select an existing Logical Device Account specification. |
Open |
Click to open the selected specification in the Logical Device Account Specification editor. |
Remove |
Click to remove a Logical Device Account specification. |
Add |
Click to add a new Logical Device Account specification. |
