Network Configuration Specification Editor Network Specs Tab
Use the Network Specs tab to select, add, and remove the Network specifications that use the Network Configuration specifications. This tab identifies the Network specifications that use the selected Network Configuration specification. You must use this tab to relate a Network specification to its Network Configuration specification only when the Network specification and Network Configuration specification need to be in separate cartridges, and the Network specification can exist without the Network Configuration specification. If both the Network specification and Network Configuration specification are in the same cartridge, make the association on the Network specification.
| Field | Use |
Network Specification |
Displays the name of the Network specification. |
Cartridge |
Displays the name of the cartridge project into which the Network specification is built. |
Select |
Click to select an existing Network specification. |
Open |
Click to open the selected specification in the Network Specification editor. |
Remove |
Click to remove a Network specification. |
Add |
Click to add a new Network specification. |
