Party Specification Editor Related Specifications Tab
Use the Related Specifications tab to define and review specification relationships. Only relationships with the entity types listed in this tab are meaningful by default in UIM. If you add specifications to the Others section, you must define custom rulesets that trigger actions or behavior based on those relationships.
| Section | Use |
Inventory Groups |
Lists the specifications of inventory groups to which party entities based on this specification can belong. |
Roles |
Lists roles to which entities based on this Party specification can be assigned. |
Others |
Lists specifications of entities that have a customized relationship with entities based on this specification. |
