Physical Device Specification Editor Related Specifications Tab
Use the Related Specifications tab to define and review specification relationships. Only relationships with the entity types listed in this tab are meaningful by default in UIM. If you add specifications to the Others section, you must define custom rulesets that trigger actions or behavior based on those relationships.
| Section | Use |
Inventory Groups |
Lists the specifications of inventory groups to which physical devices based on this specification can belong. |
Roles |
Lists roles to which entities based on this Physical Device specification can be assigned. |
Physical Connectors |
Lists specifications of physical connectors that can be provided by physical devices based on this specification. |
Network Nodes |
Lists specifications of network nodes that can represent physical devices based on this specification. |
Physical Ports |
Lists specifications of physical ports that can be provided by physical devices based on this specification. |
Others |
Lists specifications of entities that have a customized relationship with entities based on this specification. |
