Physical Port Specification Editor Related Specifications Tab
Use the Related Specifications tab to define and review specification relationships. Only relationships with the entity types listed in this tab are meaningful by default in UIM. If you add specifications to the Others section, you must define custom rulesets that trigger actions or behavior based on those relationships.
| Section | Use |
Physical Devices |
Lists the specifications of physical devices that can provide physical ports based on this specification. |
Roles |
Lists roles to which entities based on this Physical Port specification can be assigned. |
Equipment |
Lists specifications of Equipment entities that can provide physical ports based on this specification. |
Others |
Lists specifications of entities that have a customized relationship with entities based on this specification. |
