Adding Pipe Termination Point Specifications to a Pipe Specification
You can add a Pipe Termination Point specification to a Pipe specification. A Pipe Termination Point specification is required only to add characteristics. You add the Pipe Termination Point specification by including it on the Related Specifications tab of the Pipe specification editor. See "Working with Pipe Termination Point Specifications" and "Defining Specification Relationships" for more information.
