Working with Pipe Termination Point Specifications
You can include Pipe Termination Point specifications in a Pipe specification. When you create a Pipe Termination Point specification, you can include characteristics for information you want to collect. Pipe Termination Point specifications enable you to include characteristics on the termination points of a pipe and to add behaviors through rulesets. A pipe termination point identifies where one end of a pipe terminates. If you use pipe termination points, each pipe must have two, one for each end.
Defining Pipe Termination Point specifications is necessary only to add characteristics to capture specific information about the termination point.
The application creates pipe termination points without a specification if there is no Pipe Termination Point specification associated with the Pipe specification. See "Adding Pipe Termination Point Specifications to a Pipe Specification" for more information.
You create Pipe Termination Point specifications in the same manner as you create other types of specifications. See "Creating New Specifications" for more information.
See "Pipe Termination Point Specification Editor" for reference information about the tabs you use to define a Pipe Termination Point specification.
