Pipe Signal Termination Point Specification Editor Compatible Signals Tab
You use the Compatible Signals tab to select Pipe Signal Termination Point specifications that include compatible capacity unit amounts. These are capacities that the signal can support even though they are not an exact match for the main capacity unit amount. For example, you can configure a SONET STS1 51.840 Mbps channel to support a DS3 facility at a rate of 44.736 Mbps in addition to an STS transmission facility of exactly 51.840 Mbps.
| Field | Use |
Supports Signals |
Displays all supported Pipe Signal Termination Point specifications. |
Supported By Signals |
Displays all Pipe Signal Termination Point specifications that are supported by the selected specification. |
Select |
Click to select and add an existing Pipe Signal Termination Point specification. |
Open |
Click to open the selected Signal Termination Point in the Pipe Signal Termination Point Specification editor. |
Remove |
Click to remove the selected Pipe Signal Termination Point specification. |
Add |
Click to create and add a new Pipe Signal Termination Point specification. |
