Pipe Signal Termination Point Specification Editor Properties Tab
Use the Properties tab to define the capacity unit amount, unit of measure, and number of child signals.
| Field | Use |
Capacity Provided |
Displays the name of the selected Capacity Provided specification. |
New |
Click to create a new Capacity Provided specification. |
Select |
Click to select an existing Capacity Provided specification. |
Clear |
Click to remove a Capacity Provided specification. |
Capacity Unit Amount |
Enter a value relative to the selection in the Unit of Measure field. When you enter a value in the Capacity Unit Amount field, the Capacity Provided area is removed from the tab. Capacity provided information is not required for child signal termination points. |
Unit of Measure |
Click New to create a new unit of measure or click Select to use an existing one. |
Number of Child Signals |
Define this value as 0 if the signal termination point will not have any child signal termination points. Define this value as greater than 0 if the signal termination point will have children. |
